Disconnect Sub on 93 XLT | Ford Explorer Forums
diamondzen
Columbus, OH
1993 XLT
I blew the sub on my 93 XLT and just want to disconnect it. Can't for the life of me figure out how.
Thanks in advance!
DZ
The sub is located behind the passenger side plastic panel in the rear cargo compartment. Open the rear hatch and remove the plastic strip holding the carpet down. Pull the carpet away on the right side and you will find 2 or 3 (can't quite remember now) screws you will have to remove holding the trim panel to the floor. Remove the rear passenger shoulder belt bolt and the screws holding the trim panel in that doorway. Now remove the plastic anchors around the window. You should have enough movement in the panel to access the harness that runs from the amp to the sub.
