distributor, plug and wire order? | Ford Explorer Forums
catfishfiend
texas
1992 eb
howdy! i'm in the middle of a motor swap in my 92 eb explorer. i have the new engine in and mostly hooked up, when i discover one of the 'helpers' pulled all the wires from the distributor. does anyone know what order the wires go in the distributor, and what sequence they go to the plugs from there? i am just learning this stuff, and was told if i put the wires on wrong it will fry my engine. help!
I'm assuming you mean on the coil pack.. since there is no distributor.
The correct order is..
<back>
3 4
2 6
1 5
<front>
and the engine is numbered
3 6
2 5
1 4
~Mark
exactly! i knew it was 'distributorless', just didn't know what to call the coil pack. i guess i'll call it a coil pack! thank you so much for your help!
