Paul Fithian
- October 12, 2016
- Long Beach, IN
- 2007 Job 1 RWD V8 Limited
I recently replaced all suspension components on my 2001 Sport Trac, including new camber adjusting bolts.
Here's the setup I used to align the front end. Set lift even on both sides with the torsion bolts before starting.
Run a string around the back wheels to a cinder block on both sides. Set string height to the center of the wheel. Adjust toe in/out with steering wheel centered.
Use a magnetic angle finder attached to the brake disc. Adjust camber to 90 degrees with the lower control arm raised with the jack so that the 4' level on the front cross support is level.
You have to verify that the front wheels are on a level surface to do this properly.
