Do anyone no the ohm spec for a 4.0L explorer | Ford Explorer Forums
lilmonster
2004 ford explorer
Im testing the resistance to see if my crankshaft sensor is good.
Mine is around 450 ohms. If it's not zero ( short ) or infinite ( open ) it's probably not the problem.
Well if the resistance is not to spec for the crankshaft sensor then it is bad. I suspect it's the crankshaft sensor because it shows almost all symptoms of it being that and my engine turns over but wont spark. I'm going to check the ohms again for the sensor because I first did it on the scale of 20 and got a reading of .6
