chohomages
- August 3, 2024
- New Braunfels, tx
- 2016 Explorer Platinum
I'm in the process of replacing the water pump, oil pump, and timing components on a 2016 Explorer Platinum. My wife mentioned she smelled burning oil when she got out of the car, and when I crawled underneath, I found coolant dye everywhere. It doesn't appear to have been leaking for long—the coolant level was just barely below the low mark, and it never overheated.
While waiting on the oil pump to arrive, I figured I'd go looking for problems where they might not exist and ran a borescope down the spark plug holes of each cylinder. All but two cylinders had enough clearance for me to articulate the camera back up to view the valves. In cylinders 2 and 6, I noticed a small grain of something I couldn’t identify. The valves in cylinder 6 also show a pattern that the others do not. That might just be due to lighting differences, but I’m not sure.
It's possible the debris fell in after I removed the plugs, but I’m also wondering if it might be a piece of something internal that broke off—hoping someone here might recognize it.
I don’t have enough experience looking at pistons and valves to know if anything I’m seeing is cause for concern. I'm really hoping to get this buttoned up and squeeze another 100K out of the engine.
Thanks in advance for any insight.
