Sorry guys. I should have provided more info. I asked in another post but did not have the radio itself until yesterday when it arrived. So I was just guessing. Now that I have it and can see what I need more I can re-ask
Sorry to be such a noob
I have a 2000 EB AWD 4 door V8 explorer with the factory premium MACH sound.
I want to install a Pioneer AVIC-F700BT radio. The factory radio has 3 of those red connectors like I pictured above. Of course they are different sizes. I assume one is for the Steering wheel/CD changer controls. One is for the power and the other for the speakers. I could be wrong of course.
EDIT: I found them I think:
http://www.installer.com/item/display_item.php?it=71-5700
I would like to put this in myself. I would like to just plug into the red speaker and power adapters that are there with a female connector then into the new radio. Nice and neat.
If that Metra 70-5700 Auto Stereo Wire Harness fits into the red connectors then that should work perfect! Thanks for pointing me in the right direction Scucci!!
The new radio comes with a connector that ends with just wires. So I need to cross match the colors. I understand they do not match in any way.
I looked at a connector at Best Buy (nothing that I need) and the guy just said "yea just match the colors". Well in no way would that work!! They are totally different!
Since mine has that large red connector(s), my only other option is to splice into every wire behind those red connectors and that would be very messy.
I would like to put the factory one back in easily if I wanted to.
Also while you guys are here, how do I remove the front panel (with the radio hole, vents etc...) since the new radio won't fit into the slot. It looks like it has to go behind that plastic frame. The hole and radio's are double DIN so that is cool. The new one is JUST a bit wider frame wise than the factory one.
