- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
Thanks for the update!
So I thought I would update this thread. I decided to roll the dice and gamble the $10 for the rear speed sensor instead of paying $100 to read the codes. That did the trick! No more ABS light and this morning I felt my ABS kick in during the rain.
The answer depends on your physical size, and dexterity
I jacked up the drivers rear wheel about 4" off the ground, just to give myself some room (always use jackstands!).
It's pretty easy to see, look where the driveshaft gets to the diff, then look up, and slightly to the right, there'll be a wire there, that's it. One bolt, 15mm (I think), and a o-ring seal that can be a little difficult to pull, and your done.
i know where to look for it, but what is the easiest way to reach the rear abs speed sensor?
do you have to jack the truck up?
is it easy to see once underneath?
thanks in advance.
Rear ABS sensor is probably most common cause of ABS light. You can check it in a few minutes with an ohm meter - infinite or no resistance means its bad. Its located on top of the rear differential and attached with 1 bolt.
Cheap and easy fix if its bad. Got mine at NAPA for 10 bucks.
Thanks for the info. I will check these and see what I get.C1198 - LF ISO Valve Coil Circuit Failure
C1101 - Intermittent valve failure.
Check for loose connections on Pins 1 and 4 (O/Y) wire at 8-pin hydraulic unit connector. if not loose.
check resistance of unit at connector
Pin 1, Pin 4 to Pin 3 = 3-6 Ohms RA Outlet
Pin 1, Pin 4 to Pin 5 = 5-8 Ohms FR Inlet
Pin 1, Pin 4 to Pin 6 = 3-6 Ohms FR Outlet
Pin 1, Pin 4 to Pin 7 = 5-8 Ohms LF Inlet
Pin 1, Pin 4 to Pin 8 = 3-6 Ohms LF Outlet
lightly tap on the unit to see if any readings change.
Welcome to this forum! Clean the sensors.
Greeting, first time poster.
I have the same problem. My ABS light only goes on after driving through snow/slush and salt in the winter time. After a couple of days it goes out. Same thing happened last year. Is it possible the slush and salt is getting into one of the connectors then after a couple of days it dries up or gets flushed out with rain or car wash?
The slush & salt work their way in between the sensor, and the metal part that looks like a gear.
Exactly. That's where I'd put my money...
If it was the sensors, it would more than likely occur all the time, not just when it's slushy and wet outside. The sensors are not going to get better or worse depending on how wet it is outside.
