Door Chime with no key | Ford Explorer Forums
drewg123
Lake Forest, CA
'98 Explorer Spt 4.0 SOHC
When I open the driver side door the chime sounds off. That is with no 'key in ignition' or no 'headlights on'. When I put the key in the ignition nothing changes. When I start the car with the door open the chime slows down.
I have placed this on a couple other forums and have had no response. I have a couple questions about how the chime works.
What controls the chime? Is it the computer? If I was to replace the computer would that possibly fix it?
Or, I know that there is a procedure to turn the chime off for the seat belt not buckled. Are there any other procedures for the 'key in ignition' or 'headlights on'?
I have seen loose wires at the ignition switch ( key ) cause this problem.
Its also possible that the GEM module is faulty.
Good luck .......
I was about to say, mine does the same. Lock the steering wheel and it stops :)
