Door Code | Ford Explorer Forums
Door Code
Louisville Ky
2005 Sport Trac
OK. So i looked in the rear passenger seat-belt well for the code. popped the panel off and looked i didn't see a bod with the code? am i missing something? anyone have different directions? any look up for the code?
2005 Sport trac XLT Premium
You have to pull the passenger side airbag out (drop the glove box, undo the 2 bolts holding it in, carefully remove), then you'll see the module. If I remember correctly, there was just one bolt, maybe 8mm, holding it on, and the code is on the top of it.
I would recommend trying the first way that swshawaii mentioned above. The only
thing i would add to the directions is:
1. get a good flashlight.
2. make sure your windshield is clean.
3. do this at night or in a mostly dark garage. (this will help cut down on the glare from
the windshield.)
i did it this way and it took all of 5-10 mins.
