ImprezaFreak
- July 8, 2006
- Northern CT
- '94 XLT
Hi. I've been a reader for a while, but this is my first post. Unfortunately its about a repair.
So to start out... I have a 1994 Ford Explorer XLT. On the driver side, it had the infamous saggy door issue and the broken door handle problem as well (i lifted up on the handle too hard trying to close it =/). I ended up replacing the entire door and the hinge pins instead of messing around with the innards.
Everything seemed fine until one day the latch (you know, the part that latches around the pin that's on the body) stopped working. It is slightly jammed up inside the body and no longer catches the door. I've been using a bungee cord to hold the door shut, because it will fly open if I make a right turn.
I guess my question is... is that easily replaceable? And if so... where can I find the parts?
Thank you!
PS: Don't mind the name, I've been using this internet handle since I was 15 (and, back then, very much a sport car enthusiast, haha).
PPS: I'll post pictures of the issue tomorrow when its lighter out and I can snap some.
Thank you!
