Door lock cylinder fell out! | Ford Explorer Forums
Keene, NH
2000 Ranger and Explorer
I just bought this 2000 Explorer Sport this past October, it only had 60k miles, as soon as I bought it and got it on the road, the alternator died on it, killed the battery, luckily it happened right in my driveway. I then found out that the previous owner NEVER used the key to open the door, because the locks were corroded. I was able to open all the locks with a little PB Blaster my roommate left in the garage, and jiggled the key enough.
So anyway, it's winter time, the roads are really bumpy with frost heaves, I kept hearing this weird rattle noise on my way home. I get home, close the door, hear the rattle again, I turn around and the lock cylinder was dangling from the door:
http://oi54.tinypic.com/oigpd0.jpg
so... has his happened to anybody before? Is there a way to fix this without using adhesive and/or taking the door apart?
It's 2:00 am and it's 4 degrees outside, I'll have to take another look in the morning, but I wasn't able to find a post about this anywhere else.
there is a spring clip that holds the cylinder to the door,it's prob laying inside the door at the bottom.you'll need to pull the panel to get it back on.
The clip will slide back around the cylinder
I ended up fixing this the next morning after my original post, that spring clip was really tight, I had to hammer it in with my flashlight, I can't imagine it just fell out like that, it must have been improperly installed at the factory.
