Door Lock Issue | Ford Explorer Forums
Door Lock Issue
chris_beaudet
South Carolina
2003 Ford Explorer
2003 Ford Explorer Eddie Bauer
I recently started having an issue with my driver's door lock. All of my other power locks work (with the keyless entry, key fob, and the switches inside the car), but my driver's door lock only works if i manually put the key into the door, or manually lock/unlock it from the inside. Any help will be appreciated.
I've come to find Ford lock actuators are pretty much junk. They usually have just enough power to lock / unlock. Does it appear to try to move. Put your hand on it and feel if the actuator is trying to move it. If so, then it's just weak. If not U may need to look at the wiring at the hinge point. Look up hinge wiring in the forums.
