Your reply it still a bit confusing. When you say "manually" do you mean you have to flip EVERY door lock one by one manually OR do they all lock at once when you press the electronic switch on the door?
I have half your problem.
My doors will not lock electronically. If I press the lock button on the keyfob OR if I hit the lock switch button on the door, I get nothing. I have to manually flip each door lock.
They will unlock though if I press the keyfob or door switch button.
When I press the lock button, I can hear a solenoid of sorts clicking on/off in the back passenger side of my SUV roughly where the PATS unit is located.
Dealer says its the PATS unit but I can hear the relay clicking so I'm guessing a wire and that the signal is not making it to the locking mech.
I've been trying to figure it out for almost 3 years, I gave up.
