WibilFordy
- December 11, 2014
- Elkhorn, Wi.
- 2002 Ford Explorer
Found this forum and lots of useful info so far . Like so many others with door lock problems I have tried many things and finally believe I have it narrowed down to a broken wire between the divers door and body. I bought this vehicle used and the door ajar light is always on and dome light will only shut of by rotating switch down or by driving a while. Over bumps the locks flutter and main interior lock switch sometime works. better with door open...so I pulled the boot of and into the cab and play with the wires and it works or does not depending if I push or pull on the cluster right. Sooo...what color or colors of wire feed the main switch? I don't see a major break or scuff on any particular one. Will I have to pull the door panel to test for power at the switch then add a jumper wire across the defective spot? Will this cure the door ajar light or do I have to monkey with that? (I already disabled the two rear door switches as it had been hit and repair there and thought that was the problem...also had a '96 with rear window switch sticking) Please help me out guys!
