Jerzey
- January 11, 2007
- Collinsville, IL formally from Atlantic City area
- 2000 Sport
Okay guys here is the rundown.
Ive got an 00 Explorer Sport 2door (obviously)
Anyhow, ive had a few problems with my doors that progressivly got worse. First started out as my drivers door wouldnt unlock with the remote. Then it became that the door wouldnt unlock with the key! So i always had to either leave the drivers window down or open the passenger door and open the drivers door via the inside handle.
Now my passenger door wont unlock. Passenger door wont unlock with the key or the remote or the inside handle. There is tension on the handle from the inside like someones holding the lock down or something when i pull the handle. And it will only stop when i try and turn the key. The lock "nipple" near the window will jiggle slightly when trying the key or the unlock button and i hear the motor, but no luck.... So now im stuck with the passenger door locked and i cant get it open to take the panel off to fix it? Also, the drivers door will open when unlocked or if locked only from the inside handle as the door lock does not unlock with the key or remote or switch?
So, im going to open up the drivers door to see whats going on with that- and hopefully that will give me an idea on what to do with the passenger door to unlock it????
Any tips or suggestions on how to get the passenger door open is awsome! Also, any suggestions on what is wrong with either door would be great too as im going to have to probably fix something.
I tried rolling the passenger window down, and putting a coat hanger down there with a bent end, hoping to grab onto possibly the lock rod and pull it up to unlock the door, but looks like i only slightly bent the rod to the lock "nipple" as it pokes out of the door further than it did before!
