I have a '97 explorer parts truck,if you are unbolting door and hinge, the lower hinge is accessed behind the kick panels. You may need to remove the dash assembly to remove the upper hinges.I already had the dash out ,when I removed mine. It will also make the door harness plugs easier to unplug.If you don't need the hinges with the doors, unbolt them at the doors.Are you replacing them?
