I tied a strong string onto the spring hook, and fed the string through the latch asy. Then with the one end already hooked in position, I pulled the string on the other end until it hooked. You might need a small screwdriver to help guide the spring hook while you're pulling with the string. Then I just cut off the string and reassembled everything.
