djblackout
- November 15, 2010
- 1998 Explorer OHV 4x4
ok so i peeked around and noticed there is one rod that is loose. it has a couple bends on it, and connects to the part of the door lock that moves. the door lock im speaking of is the one you stick your key into on the outside. but this rod is on the inside. anywayyyy... i try to connect the rod on the middle bend to the door lock, and it will work to lock the door, but once you try to unlock the rod pops out after encountering alot of hesitation.
i cant lock my doors. this is bad. and i dont have keyless. argh!
