tripplec
- November 10, 2008
- Bowmanville, ON Canada
- 2009 Explorer LTD AWD
Hi I have spent some time reading all the treads in the Technician Tips Area and checked the 02 Sport which has the 4.0 SOHC as the marking on the crossmember state. There is little info on the vacumn routing diagram. Is there a DPFE control in the EGR circuit or is that some engines other that Explorer family.
I picked up some electrical cleaning spray, quick drying no residue. I presume a quick short squirt is all the is required to clean the wire. Shop where I got it said they're sensive and could be ruined easily.
Also it appears that if the air box top section is unmounted and behind the MAS hose clamp I could squirt either direction to hit the wires without having to remove the security mounting screws. This is the smaller airbox with a square filter. Anyone done it here.
