espnfreak
- February 5, 2001
- Elgin, IL
- '99 Maxima SE-L *5spd
Heres what the dealer said:
Dealer called and said yes you have trans problems but it should be covered under warranty. They also said that they found an upper control arm and lower ball joints bad for the stearing and they would fix that too. But, they said that a computer code shows a bad DPF sensor ? and that is $160 to fix. The more I thought about it, that probably happened when you got water in the exhaust. I'm going to decline that repair. I wan't to get away with just the $100 charge toward the deductible on the ext warranty policy. Sorry for the long message. Just wanted to pass this along. You might want to ask on the board about the DPFE sensor.
Any reccomendations on what i should do?
