Dreaded door locked Issue Help! | Ford Explorer Forums
Location
Hanford, CA
98 Explorer XLT 5.0 V8
Callsign
N6TFE
ok truck is 99 Ford Explorer XLT 5.0, it’s not stock but hey, I know I have some problems I’ve got the hesitation issue but have the stuff to fix it coming, now I’ve searched and read what I can but I can’t get my back passenger door open and yes before you ask I did remove inside handle to try and push the lever back and still won’t open, so I need help two fold I need to get the door open and I need to know what I’m supposed to replace to fix it, I’ve read the threads but no one says hey these are the parts that are the issue so please y’all give me a hand, heck if anyone was close enough I would pay you to do the door stuff
I looked at it but I can’t digure out how to get the door panel off and the pics don’t work anymore
There's a photobucket picture plugin for most browsers. It will help you see the pictures in that thread that are missing.
Ok cool so is all I need to replace is the door handles or should I replace all actuators as well
^ Don't replace anything until you remove the door panel to inspect. Although faulty latches, actuators, and handles are very common failures, often times in could be simple as a stuck latch or disconnected or broken latch rod clip. These two threads may not be specific to your issue, but the pics may be useful. Removing the glass run channel for better access and visibility described in the second link should be your first step after the panel is removed.
door latch problem solved - temporarily maybe?? | Ford Explorer and Ford Ranger Forums - Serious Explorations
How To: Drivers Exterior Door Handle Replacement | Ford Explorer and Ford Ranger Forums - Serious Explorations
