drilled air box question | Ford Explorer Forums
It allows for more air flow. However, the use of a KKM or K&N filter is a better choice.
Good luck.....
It does perk things up a good bit. Adding a K&N will with out question enhance even that. It does however create a bit more under the hoon noise. I think is is a worth wile mod, if ya want a little more kick in the pants.
Just remember drill the bottom and not the top.
How many holes?
How many and what size holes do you drill? Sounds like a good idea.
I just opend the whole front right below where the filter ended. Only on the front where the smaller intake was. Pulled out a big ol' rectangle. Ground the edges round, sanded the edges smooth. All in all a bit over an hour worth of work and tlc.
i've seen some that just drilled lots of 1/2" holes. i've seen some remove the bottom half completely. up to you..
thanks
thanks for the tip....with times being tuff and all a low cost trick is just the thing I need. Thanks.......
