V8BoatBuilder
Transplanted Bostonian
- November 4, 2002
- East Brunswick, NJ
- 97 Mountaineer V8 4x4
Ok... first some background:
As most of you know, I completely gutted the old AWD t-case and drivehsafts from my 97 Mountaineer, it came stock with an AWD system. I replaced it with the 2spd legit transfer case from an Expedition (same as F150), the rear drivehsaft from a Navigator, and the front driveshaft from an F150. All junkyard parts.
I put new u-joints in the shafts (2 rear, 2 front), and everything worked awesome. I drove the truck down to Delaware and back, plus around MA. The swap has over 1500 miles and is working well. However, I've only had the front driveshaft in for the last 500 miles of that. Coming back from the DWE show, I started to get a humming/rumble from the front on coasting and decelleration from 30-75mph (I don't usually drive faster, so it's unknown if the humming stops). Press the gas, and the humming stops.
The t-case is in 2wd, but the Mountaineer does not have hub lockouts, so the front shaft is always spinning at highway speeds. The truck didn't exhibit these symptoms before.
I removed the front shaft at a rest area, and the humming went away. The u-joints are all properly greased with Mobil 1 synthetic, and turn smooth.
Thoughts?
Thoughts?
