Driver Door Issues | Ford Explorer Forums
Driver Door Issues
Jerry R
Wallingford
2003 Explorer Sport Tr
So just purchased this truck with a few issues:
Issue 1 :So the Window shimmies if you try to put it down, up?
So I'm not sure what would cause that? Thoughts? I don't want to take ir apart until I hve all the parts i need.
Issue 2: Power side mirror switch do not work?
Issue 3: The driver door does not lock. So power lock does not lock the door, but I can manually lock /unlock the door by pulling the lock. So I hear something when I unlock with the power lock button, but not when I try to lock. Same results from the fob? Thoughts?
I'm thinking lock actuator?
It just wierd to have so many problems so maybe a wiring issue?
Anyone else have these issues? How can I fix them?
Check the wiring in the drivers door jam. It has been known to find broken wires under the rubber boot. Dave P.
Is your outer door handle loose? I have similar locking issues and the springs for the handle is broken causing the handle to sometimes affect the locking mechanism. From what I've read those springs are a common issue too.
