Driver door wire bundle | Ford Explorer Forums
Gilbn1
Virginia
2003 Ford Explorer EB
Just asking, I know it's a common problem with the explorer to have wires in the bundle that runs through the driver door break. Just seeing if anyone knows a place where I can buy a prewired bundle, that I can just run to the door and replace it simple without having to pull the whole bundle out rewire it, and put it back in.
You could go to a wrecking yard and get the wires from a 2004-2005 explorer.
Though it may be part of the main harness, which means you'd still have to splice.
Or, it may all plug into different connectors under the drivers side of the dash. This means removing the individual wires from the connectors. You'd need to remove the dash. I would at least.
