ravekid
- April 12, 2004
- Wilmington, DE
- 98 Sport
I unlocked my doors with the keyless entry, and then went to pull the handle and it was super loose, with no tension at all, even less then a normal locked handle. So I tried to open it with the inside handle and that doesn’t unlock it either, although it has the normal "feel." when I do unlock it, using the keypad, keyless entry, or the unlock button, I can hear the mechanism making noise, and the little black nub that sticks pops a little but wont go up all the way like the door does when it is locked. To get the door open I put the window down and click the unlock button and when it pops a little bit I can barely grab enough to pull it up and then while holdint it up i have to pull the inside handle and i can get it unlocked. Occasionally it will work fine, and then all of a sudden it won’t work. even when the inside and outside handles are "working" the inside catches a little before it will unlock, and then outside still feels like it has a lot more play then usually. also when i use the key to unlock the door it just hits a point when i cant turn it (when it would usually unlock)
Any ideas as to what might be wrong? I haven’t opened it yet, but id like to have the parts I may need to replace or at least the extra cash to get a replacement part...
Any ideas???
Any ideas???
