Driver Side Front Wheel, Ripped Rubber Boot | Ford Explorer Forums
Stoeger
Michigan
02 Sport
2002 Explorer Sport
Driver side wheel, looking at it from the front... the little boot is ripped...
What is this part?
the small boot, in front...
what is it?
That'd be your outer tie-rod end. Fairly cheap, easy fix, just need to have a professional alignment done afterwards.
You may want to check/replace all 4 (2 inner, 2 outer) at the same time, then there's only the one alignment cost.
Thanks. I am gettting wobbles over bumps in the front end. Since this boot is ripped, there is pretty much 100% chance the part underneath is bad and it needs to be replaced?
How much can replacing this tie rod end improve/tighten up the front end? A little or a lot better?
grab it and shake it, if it doesn't perceptibly move, then not much.
Shaking over bumps is usually a sign of worn shocks, but could be a number of things, next suspect on Explorers with high mileage is ball joints.
