Driver Window Is Down / Won't Go Up | Ford Explorer Forums
jeribrock
Round Rock, TX
2001 Sport Trac
I have a problem where my driver window went down, and now it won't go up. All other windows work fine (up and down). When I press the driver down button, I hear a "click", but not when I press up. The fuse in slot #20 to the left of the steering column is fine. Fuse #12 box in the engine compartment fuse box (by the master cylinder) is fine as well.
Is there a relay somewhere that should be replaced or something else I should be checking?
I have a 2001 Sport Trac.
Could be that the switch is bad or maybe the motor took a dump.
