I've searched through the site and came up empty. Working on my g/f's 02 Explorer Sport Trac the drivers door lock will not unlock or lock with remote, keypad or inside door button. I basically jumped straight to replacing the actuator and discovered after replacing it, it still didn't work. I found out both doors use the same actuator and open up the passenger side thinking there's a chance the only one I could find in town was bad. I was wrong, the new actuator, the old one out of the drivers door both worked on the passenger side when I tested it. I inspected the wiring in the door and found nothing wrong, everything is sealed up great. I've also checked all fuses as well. One other interesting piece (she brings up at the same time) is some time ago the overhead center console just stopped working. According to the user manual that came with the vehicle that and the door locks are on the same fuse, just wondering if there's something else in common in the circuit and the overhead was an initial sign that something was going bad. Any advice would be appreciated.
