Drivers side air vent not blowing | Ford Explorer Forums
neo95
Tucson, Az
97 xlt V8 AWD
Hey guys. This is my first post here. I got a 95 xlt 4x4 a couple months ago and I love it. My forst Ford and I must say I am very impressed. Heres my problem:
My drivers side air vent doesnt blow any air. I have tried all settings from head and feet, max a/c etc. The only time it will blow is if I close all other vents and then it only blows a little. I cant really see anything from looking under the dash so I dont know if its disconected a little or something. Is this a common prob or have any of you had this prob before? Any suggestions on where to start w this?
Thanks alot guys. This site is great and I have been able to answer bunches of questions just through searching around.
I just replaced some guage bulbs and the vent seems to be connected. At least as far as I can see. Any ideas? Cold air seems to flow a little better than hot
I'm having the exact same problems. Only I haven't replaced my dash bulbs yet to look. Hysterically, I too need to replace the dash bulbs. All but 2 or 3 are burnt out.
Holy old thread.
Neo, did you not solve the problem 7 years ago?! :O
old thread not withstanding, most vehicles have hoses connected to the ac/heater plenum which then go to the side vents. sometimes the same is accomplished using plastic ducting, but in any case, if you're not getting much output from a given vent, a hose/duct has probably has come loose somewhere under the dash. you may get to see something if you pull the radio out, but i'm not sure.
Holy old thread.
Nope, nor have I fixed it on my current Explorer. I actually forgot I had posted about this again when I got my current truck so sorry for revising such an old thread. In my other post, someone mentioned a partially opened blend door being a possible culprit. My blend door is definitely broken as they all seem to become so I'm thinkin that might be my problem. My A/C only blows cold in "MAX A/C" mode which means the blend door is stuck. I know you can cut an access panel and manually open/close it. Might have to try if I ever figure out my transmission problem. http://www.explorerforum.com/forums/showthread.php?t=257801
