Drivers Side Window is Disabled by Mechanic, now how do I enable it? | Ford Explorer Forums
Janeserious
1996 Ford Explorer
I had trouble with my 96 explorer driver side window. It kept falling down into the door. I had a guy working on it, but he didn't fix it. He did disable the button for that window only. I can not figure out or find where he did this. I checked the book and can't find anything about windows in the fuse box. Does anyone have any idea how this button would have been disabled? All the other buttons on the drivers side work, just not the drivers side window.
I'm going nuts replacing the window myself. I got it into the slot and ready to bolt, but can't raise the bar to meet the tabs on the window, since the button is disabled. Any help would be so appreciated. Thanks
He either cut the wire at the switch or cut/disconnected it at the window motor.
It wouldn't be a fuse or all the windows wouldn't work.
I got it thanks. The harness was wrapped around the bar and jammed it all up. Fixed now thank you!
Good to hear. No problem.
