JEFEW
- April 19, 2011
- Pekin,IL
- 97 XLT
I have a 97 explorer with auto trac 4wd I am getting a noise and slight vibration from the front driverside also when i look at the tire out the window it seems to be wobbling i have replaced upper/lower ball joint, left side drive shaft, and hub assembly the noise is a scraping sound that coincides with the wobbling tire any time the wheel is moving only thing i havent changed is tie rod ends and ideas?
