Drop leafs and dropblocks? | Ford Explorer Forums
WaTTz305
miami,FL
'94 XLT
If you were to put some 3" drop blocks on 3" drops leafs would it add up to a 6" drop? It only makes sense that i would lol
Yes in general but the leaf springs are a bit of a variable since how low a vehicle sits depends on its weight - which varies from Explorer to Explorer.
Also, to get that drop, you will need to put a c notch in your frame.
Yes. A notch is required for anything more than 3" of drop in the rear. Even at 3" you SHOULD cut the bump stop in half. I have a set of 3" drop leaf springs for a 1st gen X, I won't be using them anymore. I am going to go IRS in the future.
