Dtc U2025 Sdars? | Ford Explorer Forums
Dtc U2025 Sdars?
Dennis94XLT
San Diego, California
2005 XLT
I was reading the tech manual for my truck. It has an audiophile stereo and I found instructions for checking it - running diagnostics. The test to check for errors reported a code found and it reads "DTC U2025 SDARS" - This displays on the radio itself where the station information would normally display. If I turn the radio off, then back on - it comes on normally. I only get this code by running the internal diagnostic test then by pressing a button that is supposed to check for "DTCs".
Does anyone know what this is? The radio appears to work fine but the truck is under warrantee so I'd rather get it fixed if it's broken or about to break. I cleared the code several times - it comes right back. The book that told me how to run the test didn't tell me what that code was...
Any takers?
Thanks!
Satellite Digital Audio Radio System
I think it means the module is not responding, which probably means you don't have it active.
You're right that I don't have that installed - but it is an add-on option I read about.
Thanks for posting the answer.
