Dual Voice Coil | Ford Explorer Forums
Dual Voice Coil
turtle313
San Diego, CA
'96 XLT 2WD
Am I correct?
Dual Voice Coil subs provide lower impedance, higher power handling capablitlities, and better heat dissipation.
Anything else or is any of that wrong?
i wouldnt really say higher power handling capabilities... its the same as having 2 subs, only difference is that its more of a 2 in 1 sub
No, there is no advantage to dual voice coil other then wiring options, A dual 4 ohm sub wired in parallel will handle exactly what a single 2 ohm sub does.
the only diff is that you have more flexablity on what impedence you run. none of what you listed is correct.
