E-Brake Cable Q | Ford Explorer Forums
E-Brake Cable Q
Scott B.
GA
'93 Ranger XLT
Those of you with a disc brake rear end,
Has anyone needed a longer left-side emergency brake cable? I'm referring to the cable going from the wheel to the junction. If you have replaced it, what have you used?
I need a cable that is about 3" longer - not sure if an F-150 cable will fit.
Any suggestions would be appreciated.
Thanks,
Scott, I know many people have replaced that particular cable on the explorer with the ranger cable... since you have a ranger, I'm not sure what you'd use...
Scott, I forget what model Ranger you have, but maybe a Supercab cable will be longer, assuming you have a regular cab.
I would use a Ranger cable, but Rangers don't come with rear disc brakes - the drum brake cable won't attach to the actuating lever. :(
Vehicle length shouldn't matter - I need the cable from the brake to the junction. The cable from the junction forward is where the different lengths are accomodated.
I did find out that F-150 cables come in 43", 54", and several longer lengths. Hopefully, one of these will work.
how about one from a sport trac?
That seems to have a long wheel base too..
