Easy part number question… | Ford Explorer Forums
David Suesz
SE PA
1997 Mountaineer
After a lot of searching, including the archives here, I can't find the Motorcraft number for the two hook-shaped hoses between the engine and the firewall on a 97 5.0. #1 and #3 in this image-
18472 (No description) (NOT AVAILABLE) **7Z-18472-AA #1 in illustration, 1996/ 1997 ; 5.0, Ford Series
18472 Hose - Heater Water **7Z-18472-KB #3 in illustration, 1996/ 2001 ; 5.0, Ford Series 1
I would use two #3's and cut it slightly shorter for your #1 hose since they look to be identical except the length.
The Motorcraft part # is KH-584 and can be found at several online retailers along with places like oreilly's etc.
In the diagram you can't tell, but the straight horizontal part in the middle is twice as long on #1 as it is on #3. Still might work.
perhaps then you could couple another #2 to a #3 to make up for the added length of #1?
OK, got an answer.
#1 is KH-202 or F77Z-18472JC
#2 is KH-262 or F67Z-18472-BB
#3 is KH-584 or F77Z-18472-KB (and had new clamps on it)
