jagbucket
- October 16, 2013
- tacoma Wa.
- 2000 mountaineer
Newbe here but still an old guy.
i started out buying a jy 99 5.0 motor for my bronco project and the next thing i know after an $800 exchange another 2000 mountaineer/5.0 just followed me home has 205 thou. and still runs great no noises or leaks I think this last generation of the 5.0 is bullet proof. Same cannot be said for the eatc heating system. it has the run in high only fault. i have read all the posts i can find and have replaced the speed controller with a new one , replaced the fan motor with a lower mileage one with no luck .
I just found the post with the tests from the service manual that i will attempt tomorrow.. failing that how can the interior controller be tested?
The steering control does the same thing hi only, so if both interior inputs have the same problem does that point back to the new speed control ?
So far ive replaced a fender, door, front bumper headlite ass. grill and header panel the best part is all in the correct original color there's alot of these around so parts were cheap. no frame damage just bolt and go except for these electrical issues that the po just lived with ..
