ebay and resistors | Ford Explorer Forums
ebay and resistors
94Blue302GT
Lansing, IL
97 2dr sport
on ebay, do a search for "explorer chip"
good job, now, sor them "price: lowest first
they all have the same thing in common...
a resistor plugged into the IAT
does this really work?
What kind of resistor, or doesn't it matter?
I have all kinds of resistors out of computers and stuff, how do i know what ones will work, and what won't?
Hey, even if it just gives a little boost, i'd try it!
example with a link with TWO resistors, for different settings...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7956233138&category=33597
it also has a picture that says "42k ohm" on it. is that what they're using?
Shoot, really can anyone just go buy a 2 cent resistor from radioshack and try this out quick?
Try it if you wanna destroy your cats and engine parts from running rich.
well, actually, my car is running lean at the moment, even though the check engine light is off now. Every time i put a filter on it (other than stock) it gives the check engine light and the code says it's runnin way lean. maybe i could use the two in conjunction?
Those things are worthless, do not buy one. If your truck is running lean fix the problem, those things on ebay are not the answer.
