the_tool_man
- June 6, 2002
- Spartanburg, SC
- '01 Sport 4x4
Hi all:
I'm sure this has been said before, but I can't help it. I finally got around to installing my EE rear swaybar kit (ZD5622) this weekend on my '01 Sport. To summarize - it transformed the vehicle. No more funny body oscillations when traversing camber transitions. Almost no body lean in corners. It almost handles as well as my Mustang (with worn-out rubber bushings). So far, it's the best $180 I've spent on the Sport. If you want your Explorer to handle, and don't plan on doing any rock crawling, I highly recommend putting one of these on.
Installation was easy. I had one guy helping me. It took us about 30 minutes laying under the Ex in the driveway, using a pneumatic wrench. I did not remove the spare, but I did jack up the rear just enough to let the rear axle go slack. I also had to remove the lower shock bolts to provide room for the wrench. If you can change a tire, you can install one of these swaybars.
Regards,
John.
Regards,
John.
