ranger88stx
- December 4, 2005
- DE
- 88 Ranger
Ok i have been searching all of the threads on different forums. My problem is different then most others i read. I have an 88 Ranger and this is my story. Ahile back i went to put my truck in 4wd. I pushed the 4x4 button and the light came on but i did no there the relay click. Ever since then my 4x4 lights are on both hi and lo and they will not go out and the truck is not in 4x4. I checked the boards and thought it was a problem with my shift control module as when i tested it the light did not come on. just to be safe i had my mechanic check it out and he said it was also the shift control module. I went to a junkyard and got a box and tried it and it also did not work light would not light when tested. I thought maybe becaus eit was a different part number from mine that it would not work. I got one off of ebay and it is the same par tnumber and it also will not light hte test light and nothing works. Now i am thinking the chances of having three bad shift control modules is pretty slim since it is just an electronic box. I am not sure where to look from here. I have checked the wires going into the pigtail connection on the shift control module and it does get 12 volts to it when it is supposed to. I have seen some post on the motor sensor being bad but most of those state that the lights on the dash don't work as well. Does anyone know where else i can start looking?? i really wnat to get this fixed but don't want to take it somewhere to have them say the box is bad again....this thing is driving me
