Electric Lumbar support | Ford Explorer Forums
markwillenbrock
Fes, Morocco
This isn't so much a quick fix as a bodge, but it does work.
The drivers side electric lumbar support on my Ex had stopped working. It seems the valve to release the air is also part of the switch, and the spring or something broke inside it.
I had the side panel off the seat (a few screws - easy with the seat on high) and fiddled with the switch, got it working again, but then it stopped a month later.
Finally I pulled the switch off again, pulled the plastic air pipes off, blew down them as you would to inflate a balloon, stuck insulation tape over the end and rammed them back onto the switch.
Granted, I can't adjust it, but too much lumbar is better than too little and it's much more comfortable than before!
lumber suport
hi mark i can sell you a switch and the pipes. it will save you going blue in the face. cheers chris
Hi Chris
You've been very helpful in keeping my car running - but it's not as difficult as it sounds to blow the seat up!
I might treat myself to a switch next time we need something major.
