TonerBoner
- August 23, 2010
- Socal
- 1993 ford explorer sport
Ok to start off I have a 1993 ford explorer sport 2WD v6.
Yesterday day I drove through the desert and when I got home
every thing was fine. When my sister goes to start it all the electric parts
went dead like I had blown a main fuse or relay so I disconnect the
battery for 30 sec and removed the 2 top left relays.(they were elect control relay and abs relay)were there is a clicking noise comming from regardless of what ever relay is in the spot. But now when the car is off the battery light flicks on and off with a clicking noise in sync and I have no clue why that's happening, then my turn signals do not work but my haZards do it's pretty weird. Also abs light is on but I think that's cause the abs relay is out. That's all that's been happening. Please help and thanks in advance.
Sorry if typingand puncuation is bad I only have my iPhone right now.
Also I did check all fuses under the hood and under dash; does anyone have the diagram for the fuses under the dash? Thanks again
