keith7932
- April 30, 2008
- Frederick, md
I have a 94 Mazda/Explorer, I got this used so I do not know the history. The front turn signal lights do not work but the rear do. They also do not work when the four way's are on but again the rear do. They do work when the running lights are turned on. Bulbs are ok. Also the gas and temp gauge do not work. I replaced them with ones from a junk yard and also put in a new/used board in the dash but still the same. The truck runs rough like it has a choke problem. I replaced the fuel filter and the PCV valve. The anti lock brake light comes on some times and then some times does not. All brakes are new. The check engin light comes on when it is driven over 60 mph for more than a few minutes but goes off when the speed drops down for a time. I suspect more than one problem but I cannot rely on any readings until I know I have the electrial problem sorted. Wireing dirgrams are poor. After the signal wires come off the colom where do they go next and what path do they take. and what color are they. The books are not accurate so please don't quote me from them.
thankyou
Keith
thankyou
Keith
