Electrical issue | Ford Explorer Forums
Electrical issue
soonerfan1379
Shawnee, OK
1994 Explorer
I recently replace the positive terminal on battery cable. Now I have no power, no lights, nothing. I turn the key and silence. I have checked the battery, had the post cleaned. I have replaced the started relay and checked for continuity. Open to suggestions.
The truck will not start when I tried to jump it. I will check the ground.
have you checked all of the fuses? if you didnt remove the ground from the battery b4 you removed and replaced the positive you may have sent a surge through your electrical system and blown a fuse.
I have checked all my fuses, unless there are some I do not know about. I checked the panel just up from the battery and the panel below the steering wheel. Also checked my fuse link from the starter relay.
