Mommystrucky
- January 14, 2004
- Bayville, NJ
- 03 xlt
ok i took my 96 xlt in to get looked at on friday. cottman trans had this free scan and check so i figured i would do it because i have been getting some horrific mileage and it does downshift hard at times. luckily they found nothing wrong with the tranny whatsoever but....they found a code for the a/c and a whole bunch of other stuff.
the a/c stopped working a few weeks ago. i was driving with it on (hot day) and suddenly it smelled funny and got warm, i turned it off and back on and after a min it started to get cold again but then came out hot. hasnt worked since. we replaced the relay and that didnt seem to do anything. so here is what the mechanic wrote down that happened friday....
koeo or koer dtc p1460 indicated wide open throttle. a/c was off (wac) circuit fault or that a/c was on during self-test. a/c was not on during test.
koeo- no codes
koer- no codes
momory- p1460 wot a/c cutout ckt fault
that was before the test drive...during the drive more codes...here is what he wrote down
gem module codes
b1302 acc delay relay coil ckt fault
b1352 ign key in ckt fault
memory codes gem
b1323 door ajar lamp ckt fault
b1434 wiper speed relay ckt fault
b1428 safety belt lamp ckt fault
he also said that there is definate decreased power. i guess i dont really notice because i am used to it but i do notice sluggishness at times. also ever since the a/c stopped working whenever i turn on the heat or defroster or anything the rpm starts bouncing and the motor keeps reving up and down until i turn it back to off.
Does anyone have a clue what this means??? he said he had no clue what to do with any of it. theyre a trans shop so he recommended someone to me. i called and he wants to run a complete diagnostic $90. he said since i replaced the neg terminal a few months back and didnt clear the computer when hooking the battery back up it might have some of the codes because of that. so he wants to clear it and see if they come back. i dont know what to do. i dont want to have to start car shopping.
koeo- no codes
koer- no codes
gem module codes
memory codes gem
