Electrical problems | Ford Explorer Forums
Electrical problems
LimitedV8
Port Coquitlam B.C Canada
1997 Limited
Hello all new to this forum l have a few problems hopefully someone can resolve my issues.headlights-highbeams work drivinglights work but lowbeams do not fuses and bulbs are good.Second foglights do not work bulbs and fuses are good.Third brake lights do not work the only one working is the centre eye beam on top of hatch.Four automatic power door locks packed it in when brake lights died.And last front end whining noise comeing from drivers side sounds like tires but could be wheel bearing im told.The tires are bridgestone duelers top of the line and have approx 60 percent in front and 80 in back l will try and rotate to see if this stops the problem if not what are the costs for a wheel bearing and can l install it myself???Thanks for all the help.Truck has 135000 kilometres awd 5ltr.
It sounds like the daylight running unit is bad. They have been known for the connections to come away inside the unit. Can be fixed with soldering iron. Brake lights could just be bulbs. Have you checked the auxiliary fuse box? Not sure on the wheel bearings though.
Limited, please don't double post in the future. Thx
