Emergency!!! Need to remove spring coils!! | Ford Explorer Forums
Asugolf14
Littleton, CO
'93 XLT
I need to remove my springs to put the new ones in that i just got with my skyjacker lift. Anyone know how to get them off?? Any help is apprectiated. Thanks!!
stick some socket wrench extensions down the coils with a big wrench there is one bolt down there.
ok, we got the bolt off, but how do we get the springs out now??
i explained it in your other post.
Ok, so you have the frame on jack stands, and you just push down on the axle?? Thanks again for all the info!!
Alright, well that isn't working. Any one else have any other ideas?? And another question, if we take out the spring, what holds the body from comming down onto the axle?? Thanks-
Did you undo the shock and swaybar???Don't take the pivot point loose at the end of the axle..Once you take the nut loose on the bottom, the shock and swaybar loose, just twist it and it will fall right out..Make sure you have your jackstands on the frame..behind the wheel well..just in front of the the front seats..If you have anymore problems, just drop me an e-mail..good luck
