Empty gas gauge? wiring? | Ford Explorer Forums
welsh
2002 Explorer
I've received some very helpful information regarding the constant "empty" gauge reading. I've replaced the cluster and the sending unit without any change. It looks like I'm going to drop the tank enough to get to the wiring and connectors.. Question is this, is the wiring from the sender to the the cluster a straight run or are there any connectors between the sending unit and the cluster. Also, I did swap out the radio. Could I have disrupted a wire in the process. Once again I thank all of you who have helped me. Welsh
