DavidD
- August 7, 2002
- L.A. CA.
- '92 XLT 4X4
I usually dont post much on here. Cause I usually dont have any problems with my X. But today I had a problem
First of all I have a 92 XLT with around 130k miles on it. When I started my X to go home tonight it started bogging real bad and tried to die on me. The whistling type sound let me know it was a vacuum issue.
I found the culprit after feeling around for a couple of minutes. It was the vacuum tube behind the big hose that goes to the brake booster. I didnt know what line hooked up right there so I just plugged it up. Once I plugged it the X was fine. But I noticed 2 disconnected vacuum lines from there (behind the intake manifold). One of the lines was about half inch in diameter and 1 1/2 feet long and was hanging under the brake booster. The other I believe was going to that cylindrical looking object next to the foil covered thing having to do with the A/C.
I also noticed that from the small round canister located next to the brake booster there was a small line that looked wet with what appeared to be either ATF or Brake Fluid. It had sprayed on the hood and on the brake booster.
my questions are do I just leave the plug on the vacuum spout or do I hook up one of the lines? which one? what do I do with the other lines? Why was there fluid sprayed in there? why is it sunny during december in Cali?
Thanks and sorry for the long post. I was just trying to be as detailed as possible.
